195
WinGrid: Updating Cell Value
When I try following column, I get  Runtime error:'Cannot convert string value to boolean'
row.Cells(
"statuscode").SetValue(strStatusCode, True)
My Grid is bound to a datasource and all I am trying is to set new value based on user action. I havn't defined column data type explicitly. The cell value does contain string like 'Settled' when bound to the data source.
I am not sure why it is treating the data type as boolean. Will appreciate any insights you may provide.
thank you
Yogesh
  • 469350
    Suggested Answer
    Hi Yogesh,
    Are you getting an Exception? If so, can you post the call stack?
    Are you certain that the "statuscode" field in the data source is a string and not a boolean? Have you checked the DataType property on the grid column?
