Hi
I'm writing a save layout method that allows user to create their own layouts and just in case they mess up I have used the Reset() method on the DisplayLayout. But...I have used a column chooser and when the layout is reset the column chooser button vanishes.
Any idea why this happens and what can I do to fix it? Is there another Reset() method I should use. Currently I have had to use a default layout xml file to reset the layout to the defualt one, but this is just a bit of overhead I'd rather do without.
Jeff
Thanks Mike. I'll give that a try.
This is what I have done. Seemed the best option.
Thanks for the reply.
Hi Jeff,
The Reset method will return the grid to it's default settings. These are the default settings of all properties in the grid. The grid does not record the settings that you set up at design-time, including any presets that may get loaded - and a preset is loaded into the designer by default.
So if you want to establish a set of default grid settings for your application, you really need to save them yourself into a stream of a file or a layout.
I recommend saving the layout into the grid.DisplayLayout.Layouts collection. It's a convenient place to store a layout at design-time without having to write to a file.
U better save the default layout and open it when the Reset button is clicked.
