I've been working with the UltraGrid for a while. We have many grids in our forms, binded to a "BusinessObject" (BO) class through a BindingSource instance.
The problem is every time we add a new public property or collection to the BO they pop-up in the existing grids as visible columns or bands. I have more than 20 grids, so everytime BO changes I have to manually check every grid and hide the column or the band. That's very tedious and error prone.
I can not add the Browsable(false) attribute to the new properties because I do want to be able to bind them to new grids.
Is there any workaround for this?
Thanks.
oscarmorasu said:I have more than 20 grids, so everytime BO changes I have to manually check every grid and hide the column or the band. That's very tedious and error prone.
