Hello all,
Where can I find information about the UltraGridColumn class? Thanks in advance for any ideas and/or suggestions!
Hi Willy,
There is no point in calling the constructor for an UltraGridColumn. All of the constructors are used by the grid for deserialization. The only way to properly add columns into a grid band is to bind the grid to a datasource (in which case the grid will create the columns for you automatically). You can also use the band.Columns.Add method to add unbound columns, but you must have a datasource first for this to work.
Thanks. But I still could not find the descriptions about the constructors. E.g.
public UltraGridColumn(string key, int unboundRelativePosition);
What is the argument unboundRelativePosition? When would you use that?
--Willy
Hello Willy,
Could you please try these links:
http://help.infragistics.com/Help/NetAdvantage/WinForms/2012.1/CLR2.0/HTML/Win_NetAdvantage_Win_Client_Windows_Forms.html
http://help.infragistics.com/Help/NetAdvantage/WinForms/2012.1/CLR2.0/html/WinGrid.html
The link does not work. Any update?
Thanks, I eventually found that and was able to answer my question.
