I have 2 UltraPictureBox. ultraPictureBox1 and ultraPictureBox2. I added to the property ContextMenuUltra a PopupMenuTool from the UltraToolBarManager.At both PictureBoxes it’s the same PopupMenuTool. (I have only 1 PopupMenuTool)In the ToolClick event, how can I get out on wich PictureBox the PopupMenu was clicked?private void ultraToolbarsManager1_ToolClick(object sender, ToolClickEventArgs e){}
I'm attempting to do this but there appears to be a bug in this.
If I do this for a control (TextEditor for example) that is not the active control on the form it works fine. When the control has focus however, e.SourceControl is empty, no name, no control. Thoughts?
You can handle the BeforeToolDropdown event of the UltraToolbarsManager. The event arguments for this event contain a SourceControl property which indicates the control for which the context menu was shown. You can cache a reference to the control in this event and then clear it in the AfterToolCloseup event handler.
