When I delete a tool from the Infragistics toolbar, it is straight away removed from the view, but i find it still persisting when i look at the tools present in properties. How to remove a tool permanently from the Infragistics ToolBar?
Thanks.
Thanks a ton!
Hello , You can use “Cutomize” link button on the bottom site of the properties window for the ToolBarManager. This button will open a window that will display all toolbars, tools and commands. You can pick the desired command and remove it, this will remove it permanently if you use “Delete” button.
See the attached screenshot.
Let me know if this helps.Sincerely,DimiDeveloper Support EngineerInfragistics, Inc.
