I want to use the UltracomboEditor to replace .NET's ComboBox. I'm also using a BindingSource as the datasource of all my controls.
In the attached test application there's a .NET Combobox, an UltraCombo and an UltracomboEditor. The last two have the SyncWithCurrencyManager property = false. I also have an UltraGrid and a label. All controls are bound to the same BindingSource.
If I run the app, you can see all controls displaying the first item in the list, except for the UltraComboEditor. If you select a different item in the grid all controls change, except the UltraComboEditor. Now if you use that editor to select a different item yo see changes in all other controls.
In a nutshell, the UltraComboEditor affects all other controls, but the opposite is not true. I thought the UltraComboEditor replaces .NET's ComboBox, but it looks like the UltraCombo is the right way to go.
What am I missing?
Yes that's what I meant.
Support already created a ticket to look at this issue. For the time being I'm going to use the UltraCombo.
Oscar
oscarmorasu said:In the attached test application there's a .NET Combobox, an UltraCombo and an UltracomboEditor. The last two have the SyncWithCurrencyManager property = false.
Just to clarify, the sample here has SyncWithCurrencyManager on both UltraCombo and UltraComboEditor set to true, not false. I assume that was just a type in your post. :)
Anyway, this looks like a bug to me. I'm going to forward this thread over to Infragistics Developer Support so they can write it up and get it looked at.
