I am using ultrawingrid in my winforms. I am getting data from some webservices in
an asynchronous call. After getting data i am binding the grid with the data which i am getting from
web services in the call back method. I am getting the unhandled exception
"System.Argument.OutOf RangeException" randomly. I am using
Infragistics NetAdvantage for .NET 2006 Vol. 2 CLR 2.0. Please help me in this regard.
The stack of the exception:
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.Parameter name: index at System.Collections.ArrayList.get_Item(Int32 index) at Infragistics.Shared.DisposableObjectCollectionBase.GetItem(Int32 index) at Infragistics.Win.UltraWinGrid.VisibleRowsCollection.get_Item(Int32 index) at Infragistics.Win.UltraWinGrid.RowColRegionIntersectionUIElement.PositionChildElements() at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UltraWinGrid.RowColRegionIntersectionUIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UltraWinGrid.DataAreaUIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UltraWinGrid.UltraGridUIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UIElement.DrawHelper(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Boolean clipText, Boolean forceDrawAsFocused) at Infragistics.Win.UIElement.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode) at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Size elementSize) at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode) at Infragistics.Win.UltraWinGrid.UltraGridUIElement.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode) at Infragistics.Win.UltraControlBase.OnPaint(PaintEventArgs pe) at Infragistics.Win.UltraWinGrid.UltraGrid.OnPaint(PaintEventArgs pe) at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs) at System.Windows.Forms.Control.WmPaint(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
You might want to review the discussion here:
Work with a dataset bound to a grid on a separate thread - Infragistics Community
This sounds like a textbook case of illegal cross-thread operations, which UltraGrid (or most any other Windows Forms control, for that matter) does not support. You need to marshal calls across thread boundaries using the BeginInvoke method. If you search MSDN for that method, you will find articles on the subject of multi-threaded programming.
