400
Index position of the dockcontrolpane changes each time the dockstate is toggled
In the attached sample docking is implemented using the UltraDockManager object.  The sample makes use of following dock manager objects,
1)  UltraDockManager
2)  DockAreaPane  – docked bottom
3)  DockableGroupPane – holding 3 DockContentPane
When I double click on the control pane header the dock state toggles (from being bottom docked to floating and vice versa).   When the dock state is toggled for the first and the second time (by double clicking on the control pane header) the index position remains as set, however when double clicked for third time the tab position of “DockPane 2” and “DockPane 3” tabs switches their position.  Is this a known issue, we have not written any additional code which would result in this behavior?
 Note: Please change the extension of the attachment to ".zip"
spm
  • 71886
    Hello spm,
    What you are describing here was an issue which is fixed in version 8.3 and above of Net Advantage.
    Please do not hesitate to contact us if you need any additional assistance.
