4165
Drag And Drop Node In Same Tree Issue
I have a WinTree setup these three events so that I can take a node in this tree, drag it and drop in the same tree. The control has the AllowDrop = True.
private void utvDocPage_DragOver(object sender, DragEventArgs e)
e.Effect =
DragDropEffects.Copy;
private void utvDocPage_DragEnter(object sender, DragEventArgs e)
e.Effect =
private void utvDocPage_SelectionDragStart(object sender, EventArgs e)
utvDocPage.DoDragDrop(utvDocPage.ActiveNode,
DragDropEffects.Copy);
The control will let me select a node, then drag that node but when I drop it the utvDocPage_DragDrop event will not fire.
Thanks.
