I have slightly different issue. In my Ultra Tree i am having this Bounded Collection of Nodes fatched using the Dataset from the database.
i am able to add child node in the bounded Collection of nodes but i want to add a new root node in the Ultra Tree.
Requirement in my case to have Two Root Node and both having child Nodes fatched from diff Database respectively means use of two datasource in one ultra tree.
Ex:
Rootnode1 is Table1 and RootNode2 is Table2
RootNode1
ChileNode1 (Dataset 1)
ChileNode2 (Dataset 1)
ChildNode3 (Dataset 1)
RootNode2
ChildNode4 (dataset 2)
ChileNode5 (dataset 2)
Rufus
Hey Mike,
That worked....Thanks for the instant support.
Hi Rufus,
Actually, you can do this. What you would do is add the two root nodes and then call SetDataBinding on the child nodes collection of each:
UltraTreeNode rootNode1 = this.ultraTree1.Nodes.Add("RootNode1"); rootNode1.Nodes.SetDataBinding(dataSet1, "DataMember"); UltraTreeNode rootNode2 = this.ultraTree1.Nodes.Add("RootNode2"); rootNode2.Nodes.SetDataBinding(dataSet2, "DataMember");
EDIT:
You wouldn't be able to bind to two different DataSets but if you put the two tables into one DataSet, you could bind to that and the control will display both tables as siblings.
I stand corrected.
