1290
Threading + WinGrid
I am using Infragistics 9.1 and I have a WinGrid that basically displays a list of SQL connections and their status.
Within the InitializeRow event, I have this:
        private void ugConnections_InitializeRow(object sender, InitializeRowEventArgs e)
            string Server = e.Row.Cells["Server"].Value.ToString();
            string Database = e.Row.Cells["Database"].Value.ToString();
            string User = e.Row.Cells["User"].Value.ToString();
            string Password = e.Row.Cells["Password"].Value.ToString();
                ThreadStart ts = delegate() { ConnectionTest(Server, Database, User, Password, e.Row.Index); };
                Thread t = new Thread(ts);
                t.Start();
And this the method that is being threaded:
        private void ConnectionTest(string Server, string Database, string User, string Password, int rowIndex)
            ugConnections.Rows[rowIndex].Cells["Status"].Value = "Connecting...";
//removed code which concatenates all the parameters to a StringBuilder
SqlConnection conn = new SqlConnection(sb.ToString());
            try
                conn.Open();
                if (conn.State == ConnectionState.Open)
                    ugConnections.Rows[rowIndex].Cells["Status"].Value = "Connected";
                else
                    ugConnections.Rows[rowIndex].Cells["Status"].Value = "Failed";
            catch (SqlException sex)
The code runs fine, but every once in a while, I'll get an error
Object reference not set to an instance of an object. on this line:
OR
Value property can not be assigned while BeforeCellUpdate event is in progress
on this line:
Where did I go wrong?
