I have an ultragrid and 3 datatables from 3 different sources, I set datatable1 as the datasource of the ultragrid, but I don't see a way to add datatable2 as a child of row1 and datatable3 as a child of row2, any ideas? please include some code to help me figure this issue out. Thank you, Jamie
When binding the WinGrid to a Hierarchical DataSource in code, a DataRelation, using matching DataColumn objects between the DataTables, needs to be created to bind the DataTables together. This is similar to a Primary/Foreign Key relationship.One approach when binding to a Hierarchical DataSource in code is to use a DataSet. A DataSet can contain multiple DataTables, one for each hierachical level linked together through a DataRelation for each level. The following URL is a link to the Infragistics NetAdvantage Online Documentation for WinClient where information and an example on Binding to Program-Generated Hierarchical Data may be found:<http://help.infragistics.com/Help/NetAdvantage/WinForms/2009.2/CLR2.0/html/WinGrid_Binding_to_Program_Generated_Hierarchical_Data.html>Please let me know if this information is helpful or if you have any questions.Thank you.Sincerely,Mike D.Developer Support EngineerInfragistics, Inc.
