865
Labels for X-Axis columns ride up
I've upgraded from 7.1 to 9.1 and I'm having an issue with label rendering. All logic being constant the difference is shown below...
using 7.1 component with the following logic to create this orientation:
ultraChart1.Axis.X.Labels.Orientation = Infragistics.UltraChart.Shared.Styles.TextOrientation.Custom;
ultraChart1.Axis.X.Labels.Flip = true;
ultraChart1.Axis.X.Labels.OrientationAngle = -135;
using 9.1 component with the same logic:
Any ideas how I can "push" those column labels back down under the x-axis line but still keep the slanted orientation using the 9.1 version of the component?
Also note that the orientation is off in the sense that the column is not lined up on the upper-rightmost number in the label which makes it seem that there are columns for which there is no data value to plot, etc. Any ideas how to address this so it renders more like in the 7.1 version (other than reverting to the 7.1 component)?
Allen
