150
key not found error
I have defined one ultradatasource.In that i defined varous columns with their key.I placed a wingrid in the form.I set ultradatasource as datasource of this datagrid.I defined varios columns of this grid.I set their key values similar to ultradatasource.
When in grid's InitializeRow event i am accessing
e.Row.Cells["iStatus"].Value = "Select"
Then it is giving error "key not found"
 I cannot understand why this error is coming
  • 2765
    Make sure tha "iStatus" column exist in your data source. Most of the time this error is being generated when there is no matching column in the data source.
