Hi
So I have this ultranumeric editor in a form which is bound to a ultrawingrid. When the editor does not have a value initially, I can tab out to another control of click around on the form. However, when I enter a value in the numeric editor, then delete it, I am unable to tab out to another control. It seems like the editor doesnt loose foucs unless I enter a value in it (entering zero works as well).
I am sure this is simple, I tried different options none of which were fruitfull! Any suggestions would help!
Is the UltraNumericEditor bound? What property of the control are you binding?
The control itself does allow null, so I suspect it's your data source that does not.
