Is there an easy way to tell the WinGrid that the width of the combo in the column is the same as the width of the column itself. Because I have embeded a combo to a column and when I drop down the combo the width of that combo is not the same as the width of that containing cell and also when I resize the column it become worse.
The ValueList class exposes a DropDownListWidth property, which you can set to zero to make the list's width the same as that of the column in which it is embedded. It defaults to -1, which causes it to size itself only as wide as it needs to be to show the widest item.
