I have a question about the built-in tooltip.
Normally, when I change the font of the grid, then the font of the built-in tooltip will be adjusted automatically, so both grid and tooltip have the same font.
But when I set
this.ultraGrid1.DisplayLayout.Override.CellDisplayStyle = CellDisplayStyle.FormattedText;
then the tooltip font will not be adjusted to the grid font. The tooltip always seems to have the default font, no matter what font has been set to the grid.
Could this be a bug? Or what can I do to achieve that both grid and tooltip have the same font when using CellDisplayStyle.FormattedText?
My NetAdvantage version is 9.1.20091.2056.
Thanks.
Hm. That's a sort've odd side effect of the CellDisplayStyle I was not aware of.
In any case, I have forwarded this thread over to Infragistics Developer Support, as I said. So you should be hearing from them shortly. I suspect this will need to be written up for developer review.
Thanks Mike.
I'm using CellDisplayStyle when I set CellMultiLine to true in order to show multiple lines per cell.
If I don't use CellDisplayStyle then DateTime values are not wrapped to multiple lines.
I'm really not sure why this happens. To test this out, I tried this:
private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e) { e.Layout.Appearance.FontData.Name = "Wingdings"; e.Layout.Override.CellDisplayStyle = CellDisplayStyle.FormattedText; }
When I do this, I do indeed see that the tooltips are not using the same font as the grid cells.If I take out the CellDisplayStyle, it works fine.
I noticed that it also works fine if I set the FontData on the Override's CellAppearance instead of on the grid's Layout.
My best guess is that since CellDisplayStyle is skipping the appearance resolution of the editor, it's not walking all the way up to the grid for the tooltip. But since it works for the cell, I can't see any good reason why this should be the case.
That's not to say there isn't a good reason, but it bears further investigation. I'm going to forward this over to Infragistics Developer Support so they can check it out.
Out of curiosity, why exactly are you using CellDisplayStyle?
