880
ultraStatusBar causes object null reference error
The ultraStatusBar keeps causing unhanded exceptions in the Infragistics code.  This happens when the form is minimized and something triggers the statusbar to update.  For example a different thread could finish and on the oncomleted event (in the main UI thread) it might change the status back to "Ready".  When the form is maximized again you can see the error box.
Here is the stack trace.  Our code has exception management, as you can see from the stack, our code does not even execute.  It just throws an unhanded exception.
System.NullReferenceException: Object reference not set to an instance of an object.
   at Infragistics.Win.UltraWinStatusBar.UltraStatusBarUIElement.PositionChildElements()
   at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
   at Infragistics.Win.UIElement.DrawHelper(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Boolean clipText, Boolean forceDrawAsFocused, Boolean preventAlphaBlendGraphics)
   at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Size elementSize, Boolean preventAlphaBlendGraphics)
   at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
   at Infragistics.Win.UltraControlBase.OnPaint(PaintEventArgs pe)
   at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
   at System.Windows.Forms.Control.WmPaint(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
   at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
   at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
   at System.Windows.Forms.Application.RunDialog(Form form)
   at System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
   at System.Windows.Forms.Form.ShowDialog()
   at System.Windows.Forms.Application.ThreadContext.OnThreadException(Exception t)
   at System.Windows.Forms.Control.WndProcException(Exception e)
   at System.Windows.Forms.Control.ControlNativeWindow.OnThreadException(Exception e)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
   at System.Windows.Forms.NativeWindow.DefWndProc(Message& m)
   at System.Windows.Forms.NativeWindow.WndProc(Message& m)
   at Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.FormSubClasser.WndProcImpl(Message& m)
   at Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.FormSubClasser.WndProc(Message& m)
   at System.Windows.Forms.UnsafeNativeMethods.CallWindowProc(IntPtr wndProc, IntPtr hWnd, Int32 msg, IntPtr wParam, IntPtr lParam)
   at System.Windows.Forms.Form.DefWndProc(Message& m)
   at System.Windows.Forms.Control.WmWindowPosChanged(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ContainerControl.WndProc(Message& m)
   at System.Windows.Forms.Form.WmWindowPosChanged(Message& m)
   at System.Windows.Forms.Form.WndProc(Message& m)
