Everytime I enter the grid designer my settings always get lost as I navagate around. Is there a fix for this?
Hi Jose,
I'm not sure if this was ever reported to Infragistics Developer Support or if it was fixed. You will need to contact support to find out. Submit an incident to Infragistics Developer Support
Hi... I'm experiencing the same with the same version... Has this been fixed with the last release?
Hm, that's the latest. Well, if you can duplicate this behavior, then I recommend reporting it to Infragistics Developer Support. Provide as much detail as possible so they can duplicate the problem and they should be able to help. Get Help
The version number is 7.3.20073.1043
Thanks!
What version of the grid are you using? This sounds like an old bug that was fixed a long time ago.
