Hello NG,
is it possible to create the following behaviour with the ultracalendercombo
The format for date is German (02.11.2009).
The user enters 0211 --> on lost focus the Value should be 02.11.2009
Th user enters 02 --> on lost focus the Value should be 02.11.2009
I have a certain month Value stored in a variable (e.g. 2 for february). The user enters 02 in the ultracalendercombo --> on lost focus the control should have the value 02.02.2009.
Thanks in advance for your help!
Stefan
If you set AllowNull to false, the ValidationError event will fire when the user tries to leave if the contents cannot be parsed into a DateTime. You might be able to handle the event and change the value when the e.ErrorValue returns a value like the ones you listed here.
Another approach would be to use the IEditorDataFilter interface to intercept the values as they are passed between the editor and the control, and change them. The control's embeddable editor exposes a DataFilter property (of type IEditorDataFilter); you can get a reference to the control's editor like so:
Infragistics.Win.UltraWinSchedule.CalendarCombo.CalendarComboEditorUIElement embeddableElement = this.ultraCalendarCombo1.UIElement.GetDescendant( typeof(Infragistics.Win.UltraWinSchedule.CalendarCombo.CalendarComboEditorUIElement) ) asInfragistics.Win.UltraWinSchedule.CalendarCombo.CalendarComboEditorUIElement;EmbeddableEditorBase editor = embeddableElement != null ? embeddableElement.Editor : null;
