55
Problem with PerformAction
I have borrowed the code provided by infragistics to make the cursor behave like excel.
The following 2 lines of code cause the error message -
Me.grdfireplace.PerformAction(UltraGridAction.ExitEditMode, False, False)Me.grdfireplace.PerformAction(UltraGridAction.BelowCell, False, False)
 Unable to convert data value. Value could not be converted to system.decimal.
This occurs from the compiled program. when I am enter a 0  or a 0. or blank into a decimal field and i try to perform the lines of code.  I would like to force the cells to be 0,00 and I would be good.
I believe the Keyup event occurs before the beforecellupdate  or any other event I could used to intercept and correct the abnormal 0 value.
Can anybody tell me how to solve this?
I love the capability except for this issue
Arnie
The Entire subroutine follows below.
Private Sub grdfireplace_KeyDown(ByVal sender As Object, _
ByVal e As  System.Windows.Forms.KeyEventArgs) _
Handles  grdfireplace.KeyDown
' Perform action needed to move cursor
Select Case
e.KeyValue
Case
Keys.Up
Me.grdfireplace.PerformAction(UltraGridAction.AboveCell, False, False)
e.Handled =
True
Me.grdfireplace.PerformAction(UltraGridAction.EnterEditMode, False, False)
Case
Keys.Down
MsgBox(
"1"
MsgBox(
"2")
MsgBox(
"3")
e.Handled =
True
Case
Keys.Right
Me.grdfireplace.PerformAction(UltraGridAction.NextCellByTab, False, False)
e.Handled =
True
Case
Keys.Left
Me.grdfireplace.PerformAction(UltraGridAction.PrevCellByTab, False, False)
e.Handled =
True
End Select
End Sub
  • 69832
    Suggested Answer
    You should be able to handle the BeforeExitEditMode event, and set the editor's Value to 0.00. When that event fires, the grid's ActiveCell property will be non-null, and you can get a reference to the editor via the UltraGrid.ActiveCell.EditorResolved property.
