70
Set date back to null
I have a grid with a date that is nullable but when I set the date and then want to clear it, it will not let me set it back to null.   How can I do this?
I am using Entity Framework for my data
  • 10
    To enable a Infragistics grid date column to allow null value, try the following steps:
    1) In your business object class (a bindable data source that binds to the grid), create a property using the nullable date type:
        Public Property YourOptionalDate() As Nullable(Of Date)
    2) Then set these Infragistics Grid settings:
        Me.UltraGrid1.DisplayLayout.Bands(0).Columns("YourOptionalDate").Style = Infragistics.Win.UltraWinGrid.ColumnStyle.Date
        Me.UltraGrid1.DisplayLayout.Bands(0).Columns("YourOptionalDate").ButtonDisplayStyle = Infragistics.Win.UltraWinGrid.ButtonDisplayStyle.OnMouseEnter
        Me.UltraGrid1.DisplayLayout.Bands(0).Columns("YourOptionalDate").Nullable = Infragistics.Win.UltraWinGrid.Nullable.Nothing
    Then you will get a grid with a optional date column that correctly displays null. Hope it helps.
    Bernard Pang
  • 469350
    Suggested Answer
    If setting Nullable on the column works, then you might want to just get the latest service release. This was a bug that was recently fixed. Setting Nullable is fine, but you should not have to do set it, the grid should be (and is, now) smart enough to recognized nullable types.
  • 69832
    Suggested Answer
    I'm not certain how the column will deal with nullable types but you should take a look at the UltraGridColumn.Nullable property.
