305
please i have 2 questions
1) There are any way to show an object inside another object into a grid view?
ej: public class MyObject1
        public string object1{ get; set; }
        public MyObject2 obj2{ get; set; }
public class MyObject2
        public string name{ get; set; }
        public string LastName{ get; set; }
row : object1 | name | LastName
2) question
if i bind a win grid with and object, Whenever i change anything in the row ,the object changes , which is fine.Now, if i do not want to have that change saved i press "close",but the object itself gets changed.
i'm wondering whether i can follow the about procedure without resulting in the object being changed.
THANKS
  • 469350
    Verified Answer
    1) Not directly. You would have to add a couple of unbound column to the root band in the grid and then use the InitializeRow event to populate the unbound columns from the object properties. If these are to be updateable, then you would also have to reverse this process - probably in the BeforeRowUpdate event.
    2) The grid is always going to write changes to it's DataSource. There's no way around that. If you bind the grid to a DataSet or DataTable, then the DataSet or DataTable have built-in functionality to track changes and gives you the ability to undo them. So this is something the data source needs to handle, it cannot be handled by the grid.
    Perhaps what you could do is bind the grid to a copy or clone of your objects so the real ones will not be affected.
