810
Why does DataSet.GetChanges returns all tables when only 3 were modified?
I have a reasonably complicated database with 18 tables that I load into a dataset and then call AcceptChanges to make sure I am at a neutral position. I then give the DataSet to the UltraGrid via a BindingSource,  go into update mode and delete one row for a table that should only affect two other linked tables. I have established many relationships between the tables but this table only has 2 relationships.
To post the data back to the database, I call DataSet.GetChanges hoping to be efficient but I get all 18 tables back albeit many have 0 or 1 row in them. I am not able to update the database unless I update every table as skipping the ones that have 0 rows causes a concurrency violation. Can anyone shed any light on why I get all my tables when calling GetChanges when only 3 should be affected? Or the proper technique after the grid touches the dataset in order to get only the ones that I really have to update? This has me stumped. Thanks, Dave
