When I set the MaskInput for a column to "nnnn" and set the CellAppearance.TextHAlign to "Right", it causes my values to be cut off when a cell is in edit mode till cell gets repainted while in edit mode, at which point it then displays correctly. I tested both with and without a MaskInput being set, it only occured when the MaskInput was set.
Sets to reproduce:
Is there a hotfix for this issue or a way to work around it so that it displays correctly initially?
I tested this out with the latest version and I could not reproduce this behavior. I think this is probably a know bug that is already fixed, so just get the latest service release:
