I'm using the UltraListView in Icon-View. For every Item i'm assigning an image. These images are 512x512 pixels in size.
By default, the user sees the ListView with a smaller imagesize like 80x80 for example. He can then move a slider on the form to resize the images from 16x16 up to 512x512.
This resizing is done via (lvBrowser is the UltraListView in IconView-Mode):
this.lvBrowser.ViewSettingsIcons.ImageSize = new Size(ultraTrackBar1.Value, ultraTrackBar1.Value);
This works great but with one problem:
At some point the Icons are too big to fit on the screen inside the ListView - so normally i would expect to get a vertical Scrollbar automatically, but this doesn't work. No Scrollbar appears!
The Scrollbar appears after i resize the form a little bit (the ListView is dock=fill on a panel which can be resized by resizing the form or moving a slider). This little resize makes the ListView showing it's scrollbar - but that's not a solution, right? :)
I've tried: lvBrowser.Update(); and .Refresh() and .Invalidate() with no success.
Thanks a lot
Here is a work around:
After setting the "ImageSize" it helps if you set the "ItemSize" to a new value too. Hope that will help others too :)
I am speculating but most likely the scroll metrics are not being updated in this scenario; you might want to report this as a bug.
