hi!
Is there a chance to find out which columns in a grid have been loaded with the DisplayLayout.Load(MemoryStream ms) method and which columns have not?
Imagine the following situation:
Version 1 of the program:
select a,b from table
Columns in the Grid: A, B
The user saves this DisplayLayout
Version 2 of the program:
select a,b,c from table
The user loads the existing DisplayLayout from the database.
Now, only columns A and B should be displayed and C should be hidden.
By default, all three columns are displayed in the grid - i want to hide column C. How can i find out that only A and B have a stored DisplayLayout?
Thank you in advance!
Andi
thank you Mike!
Thats the solution!
Yes. Instead of loading the layout into the grid's DisplayLayout, create an UltraGridLayout variable and load the layout into that. You can then examine the columns and bands in the layout. If you decide to load the layout into the grid, you can load it directly from the variable, rather than loading it from a file again, by using grid.DisplayLayout.CopyFrom.
thank you for the suggestion - i thought about that, too.
but with xml i am worried about the size it takes and the performance of parsing the xml... the layouts are retrieved over a webservice, so i have to take care of network traffic a lot.
i thought that i might maybe be possible to perform a DisplayLayout.Load() and then access the loaded Columns through some kind of property or something....
Maybe you could save the layout in xml format using DisplayLayout.SaveAsXml. Then you can parse the xml file. just a workaround. :-)
