When doing a CTRL + Drag of an appointment (which by default behaviour creates a new appointment with the same details as the dragged appointment) why does the _BeforeAppointmentRemoved event get fired?
This is causing me a great deal of grief as I am capturing "REAL" deleted appointments.
If this can't be avoided... is there some way of "filtering" out these erroneous deleted appointment events?
Thanks In AdvanceAaron
i can only assume this was happening due to debugging break points in my codes.
You did not mention the control with which you were experiencing this problem so I tried UltraDayView and UltraMonthViewSingle. I was not able to reproduce the behavior you describe here with either control using a simple test; you should report the issue via the web support form so that you can provide the details necessary in order to reproduce this behavior.
