Hi,We work real time data, that is updated on many user screen's grid very frequently. We are now in the early stages of the application, so for now we do not have any performance issue. We are required to scale this application to be able to show about 10000 rows of data which gets modified in real time.My question is, we can either have a DataSet/DataTable as the datasource or Collection of a custom object.Is there any difference in performance in using any of these methods?. I personally prefer using the Collection, as it it much neater way of implementing.
DataSets definitely have some performance issues. For example, when the BindingManager attempts to retrieve the child rows for any particular parent row, the DataSet has to build the list of child rows by looping through all of the rows in the child table and determining which ones match the relationship.
In a collection, you typically have the child rows stored in a child collection, so this is generally much more efficient.
The DataSet is more powerful in that it builds the child lists dynamically and is easier to deal with in code. But you pay a price for that flexibility in terms of performance.
That's probably the biggest difference between the two.
Oh... and if you are binding a WinGrid to 10,000 rows, I advise you to check out the WinGrid Performance Guide and also this post: Wingrid Performance and DataSources - Infragistics Forums
I think most of the bottlenecks are related to the way the control responds to notifications from the data source, for example, not being efficient about regenerating collections, etc. UltraGrid has been optimized for maximum performance however, so the question comes down to a comparison between the DataSet/DataTable and a collection. The grid is basically oblivious to which one it is bound to, as it goes through the IBindingList or IList interface to communicate with the data source. If the collection implements IBindingList, and (for example) is not efficient about the way it issues notifications, that could factor into performance since the grid has to respond to these notifications, and if it gets more of them than is necessary, that could impede performance on a level that would be unavoidable for the grid.
