after installing the hotfix 2009.2.2035 for WinForms I get the error below. I updated from 2009.2.1003. In version 1003 exporting an ultrawingrid to excel works fine.
bei System.Drawing.Graphics.GetHdc() bei System.Windows.Forms.Internal.WindowsGraphics.FromGraphics(Graphics g, ApplyGraphicsProperties properties) bei System.Windows.Forms.WindowsGraphicsWrapper..ctor(IDeviceContext idc, TextFormatFlags flags) bei System.Windows.Forms.TextRenderer.MeasureText(IDeviceContext dc, String text, Font font, Size proposedSize, TextFormatFlags flags) bei Infragistics.Win.DrawUtility.MeasureStringHelper(Graphics gr, String text, Font font, Size layoutArea, StringFormat stringFormat, Int32& charactersFitted, Int32& linesFilled, Boolean returnElementsFitted, GdiDrawStringFlags drawStringFlags) bei Infragistics.Win.DrawUtility.MeasureString(Graphics gr, String text, Font font, GdiDrawStringFlags drawStringFlags) bei Infragistics.Win.DrawUtility.MeasureString(Graphics gr, String text, Font font, EmbeddableEditorOwnerBase owner, Object ownerContext) bei Infragistics.Win.EmbeddableEditorBase.GetTextSizeOfValue(EmbeddableEditorOwnerBase owner, Object ownerContext, Boolean allowMultiline, Int32 maxWidth, Boolean isTooltip) bei Infragistics.Win.EditorWithText.InternalGetSize(EmbeddableEditorOwnerBase owner, Object ownerContext, Boolean valueOnly, Boolean full, Boolean includeBorders, Int32 maxTextWidth, Boolean allowMultiline, Boolean includeOwnerPadding, Boolean isTooltip) bei Infragistics.Win.EditorWithText.GetSize(EditorSizeInfo& sizeInfo) bei Infragistics.Win.EmbeddableEditorBase.GetSize(EmbeddableEditorOwnerBase owner, Object ownerContext, Boolean valueOnly, Boolean full, Boolean borders, Int32 maxTextWidth) bei Infragistics.Win.UltraWinGrid.RowAutoSizeLayoutManagerHolder.RowAutoSizeCalculator.GetIdealCellSize(UltraGridColumn column) bei Infragistics.Win.UltraWinGrid.UltraGridRow.CalculateAutoHeight() bei Infragistics.Win.UltraWinGrid.UltraGridRow.get_HeightIncludingPadding() bei Infragistics.Win.UltraWinGrid.UltraGridRow.get_BaseHeight() bei Infragistics.Win.UltraWinGrid.UltraGridRow.get_TotalHeight() bei Infragistics.Win.UltraWinGrid.VisibleRow.GetTotalHeight(Boolean adjustForOverlappedBorders) bei Infragistics.Win.UltraWinGrid.VisibleRow.GetTotalHeight() bei Infragistics.Win.UltraWinGrid.ViewStyleOutlookGroupBy.OrientVisibleRowForward(VisibleRowFetchRowContext& context, VisibleRow visibleRow) bei Infragistics.Win.UltraWinGrid.ViewStyleBase.InsertRow(VisibleRowFetchRowContext& context, VisibleRow visibleRow, Boolean insertDescendantRows) bei Infragistics.Win.UltraWinGrid.ViewStyleBase.AddSiblingRows(VisibleRowFetchRowContext& context, VisibleRow parentVisibleRow, UltraGridRow firstSibling) bei Infragistics.Win.UltraWinGrid.ViewStyleBase.RecreateRowList(RowScrollRegion rsr) bei Infragistics.Win.UltraWinGrid.RowScrollRegion.RegenerateVisibleRows(Boolean resetScrollInfo) bei Infragistics.Win.UltraWinGrid.RowScrollRegion.RegenerateVisibleRows() bei Infragistics.Win.UltraWinGrid.RowScrollRegion.WillScrollbarBeShown(ScrollbarVisibility assumeColScrollbarsVisible) bei Infragistics.Win.UltraWinGrid.ScrollRegionBase.WillScrollbarBeShown() bei Infragistics.Win.UltraWinGrid.ViewStyleBase.AddBandHeaders(ColScrollRegion csr, UltraGridBand band) bei Infragistics.Win.UltraWinGrid.ViewStyleVertical.RecreateHeaderList(ColScrollRegion csr) bei Infragistics.Win.UltraWinGrid.ColScrollRegion.RegenerateVisibleHeaders() bei Infragistics.Win.UltraWinGrid.ColScrollRegionsCollection.InitializeMetricsHelper() bei Infragistics.Win.UltraWinGrid.ColScrollRegionsCollection.InitializeMetrics() bei Infragistics.Win.UltraWinGrid.UltraGridLayout.ApplyLoadedBands() bei Infragistics.Win.UltraWinGrid.UltraGrid.Export(IUltraGridExporter exporter) bei Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter.Export(UltraGrid grid, Worksheet worksheet, Int32 startRow, Int32 startColumn) bei IBIS.WiPakRBEPlusClasses.cGenerateExcelSheet.GenerateExcelSheet(Workbook& oExcel, Boolean& bHasCheckLogic, Boolean& bHasContent) in D:\VS2005\WiPak\WiPak-Framework\WiPakRBEPlusClasses\cGenerateExcelSheet.vb:Zeile 513.
I reinstalled 2009.2.1003 and the export is working. So the hotfix is destroying my application. I also tried to install the hotfix 2017 with the same result as in .2035.
Note: The generation of the exel sheets is running not running in the main thread!
Thank you for any help!
Cheers
Michael
Thank you for the quick reply. The version 20092.2035 (released on 11/13/2009) is the lastest service release that I can download. I also posted a support request on 11/18/2009 (case ID CAS-35470-WYGHCQ) but didn't receive any answer.
Is there a newer hotfix available?
That sounds a lot like a bug that has since been fixed. I believe the current service release contains the fix, but you can contact Developer Support if you want make sure before dowloading it.
