I´d like to add a button in an UltraGridColumnHeader, how can I do this?
Thank you for your help.
Andres!
Hi Andres,
There is no built-in functionality in the grid for adding a button to a column header. To best of my knowledge you can use CreatinFilter in order to add a component in the header. We recently add a functionality for check box in the header area.I found similar discussion of this technique here:http://forums.infragistics.com/forums/p/24782/95621.aspx#95621
I hope this is helpful.Sincerely,DimiDeveloper Support EngineerInfragistics, Inc.
