I am using this code but it has a couple of problems: 1. it does not focus to that cell 2. I see some other problems, such that if I move away and then change the cell it does not complain again!
void gridDiscounts_AfterCellUpdate(object sender, Infragistics.Win.UltraWinGrid.CellEventArgs e) { this.IsDirty = true; if (e.Cell.Column.Key == "Name") { foreach (Infragistics.Win.UltraWinGrid.UltraGridRow row in this.gridDiscounts.Rows) { if (e.Cell.Row != row) { if (e.Cell.Value != null && row.Cells["Name"].Value != null && e.Cell.Value != DBNull.Value && row.Cells["Name"].Value != DBNull.Value) { if (String.Compare(e.Cell.Value.ToString(), row.Cells["Name"].Value.ToString(), true) == 0) { MessageBox.Show("This name already exists"); e.Cell.Row.Activate(); e.Cell.CancelUpdate(); e.Cell.Activate(); e.Cell.SelectAll(); e.Cell.Value = e.Cell.OriginalValue; break; } } } } } }
I am just checking about the progress of this issue. Let me know If you need my further assistance on this issue?
I just wanted to know if you were able to solve your issue based on Mike's suggestions or you still need help? Just let me know.
Thank you.
Hello ,
If you are using a DataTable for your underling data source, you could use Unique property of the DataColumn of the DataTable. More about this property you could find here:
http://msdn.microsoft.com/en-us/library/system.data.datacolumn.unique%28v=vs.71%29.aspx
if you set it to true, it will prevent having a cells with duplicate values in the DataTable and also in the UltraGrid.
Please let me know if you have any further questions .
