Hello!
I would like to remove the description text in front of the AddButton (UltraGrid.DisplayLayout.AddNewBox.Prompt="") and simply use the Caption on the AddButton (UltraGrid.DisplayLayout.Bands(0).AddButtonCaption="MyCaption").
When I do like this, the Button ends up all the way to the left in the addnewarea, withput any padding whatsoever... I looks like rubbish to be honest ;-)
Before, I used a small peace of text and then I made the AddNewBox.Appearance.Forecolor into white which was the background color of this area. it then came invisible and things looked good. Not I am using AppStyling and Office2007black and that doesn't work for me any longer.
Anyone that has an idea of what to do...?
Thanks for your help!
/Henrik
Hi Henrik,
Sorry about that, I should have commented the code the first time. :)
public class AddNewBoxHiddenCaption_DrawFilter : IUIElementDrawFilter { #region IUIElementDrawFilter Members bool IUIElementDrawFilter.DrawElement(DrawPhase drawPhase, ref UIElementDrawParams drawParams) { // We should only get in here for a DependentTextUIElement that is a child of an // AddNewBoxUIElement - because that's what GetPhasesToFilter is returning. // Just to be safe, we could do some sanity checks here. // if (drawParams.Element is DependentTextUIElement == false) { Debug.Fail("DrawElement is firing for an element that is not a DependentTextUIElement; unexpected."); return false; } if (drawParams.Element.Parent is AddNewBoxUIElement == false) { Debug.Fail("DrawElement is firing for an element that is not a child of the AddNewBoxUIElement; unexpected."); return false; } switch (drawPhase) { case DrawPhase.BeforeDrawForeground: // Return true to indicate to the grid that the drawing of the foreground for this // element has already been handled. The grid will not draw any foreground, and // since we did not draw anything, either, the foreground drawing is effectively // cancelled. // return true; default: // GetPhasesToFilter never returns any other phase besides BeforeDrawForeground. So // we should never get here. Debug.Fail("DrawElement is firing for a pahse other than BeforeDrawForeground; unexpected."); break; } // Do nothing. return false; } DrawPhase IUIElementDrawFilter.GetPhasesToFilter(ref UIElementDrawParams drawParams) { // Look for a DependentTextUIElement that is a child of the AddNewBoxUIElement. // This is the element that draws the AddNewBox caption. // if (drawParams.Element is DependentTextUIElement && drawParams.Element.Parent is AddNewBoxUIElement) { // Fire the BeforeDrawForeGround phase. return DrawPhase.BeforeDrawForeground; } // Do nothing. return DrawPhase.None; } #endregion }
It works, even if I use InitializeLayout. I missed to set a character instead of a null string as AddNewBox.Prompt. Sorry for that...
Before we close this thread, could you please write a few lines explaining what this code really does? I haven't been working with drawfilters before and i suppose that this code in some way or another cancels the draw operation for the addnewbox prompt text...
thanks for a good solution!
/henrik
The code you have here looks fine to me. Are you saying this is not working?
Maybe InitializeLayout is too late. Try using Form_Load.
Hello Mike!
Thanks for the code. I have implemented to code in my project (except for the *region* thing) . unfortunately I am not sure how to use this since I haven't used any drawfilters before. I am not sure what they do...
What I did was the following: (in the initializelayout event of the form)
ug.DrawFilter = df (ug ismy ultra
I suppose that you will have to explain this a bit more for me to understand... sorry for that ...
Sorry, that was a bad suggestion. Setting the ForeColor will not work, since it just gets overriden by the isl file.
You will need to use a DrawFilter. In this case, it's a pretty simple one:
public class AddNewBoxHiddenCaption_DrawFilter : IUIElementDrawFilter { #region IUIElementDrawFilter Members bool IUIElementDrawFilter.DrawElement(DrawPhase drawPhase, ref UIElementDrawParams drawParams) { return true; } DrawPhase IUIElementDrawFilter.GetPhasesToFilter(ref UIElementDrawParams drawParams) { if (drawParams.Element is DependentTextUIElement && drawParams.Element.Parent is AddNewBoxUIElement) { return DrawPhase.BeforeDrawForeground; } return DrawPhase.None; } #endregion }
