380
sorting the rows in grid by value
I have a grid. In this grid there are two columns that I need to work on. The thing is that each record in the grid will have a Reference Number which will be column 1. Not unique by the way. So the records will be grouped by column 1.  Each record can be of three types A, B and C which is laid specified in column 2. Also, for each set of records grouped by column 1, they are sorted by column 2 with type A being on top. Are there any built-in grid functions that I can use to accomplish this?
  • 469350
    Verified Answer
    Sure. You can group using the grid's OutlookGroupBy feature.
    What I would so is use the InitializeLayout event of the grid.
    Set the layout.ViewStyleBand to OutlookGroupBy to enable grouping.
    Then you do something like this:
    // Group the Reference number column
    e.Layout.Bands[0].SortedColumns.Add(e.Layout.Bands[0].Columns["Reference Number"], false, true);
    // Sort the category column
    e.Layout.Bands[0].SortedColumns.Add(e.Layout.Bands[0].Columns["Category"], false);
