775
Customizing Context Menu Option Strings - Hide, Auto Hide, Floating
I'm trying to customize the resource strings for Hide, Auto Hide and Floating in WinDockManager. I have code that looks like this:
Infragistics.Shared.
ResourceCustomizer rc;
rc = Infragistics.Win.UltraWinDock.Resources.Customizer;
rc.SetCustomizedString(ContextMenuAutoHide, "my new translated string");
However, it seems I don't have access to ContextMenuAutoHide/Hide/Floating. I'm trying to figure out if this because of where I'm putting this code or because this feature is later than Infragistics 7.3 (the version I'm on).
Right now I have this code in the same place where I use UltraDockManager to dock my control panes. Maybe this is not the right place and thus the reason for not having access to ContextMenuAutoHide? ...
I have been using the following link to guide me in this implementation:
http://help.infragistics.com/NetAdvantage/NET/Current/CLR2.0/?target=Win_Customizing_Assembly_Resource_Strings.html
Any help in this area you could give me would be greatly appreciated.
Thank you,
Steve
  • 12773
    Hello Steve,
    I am not sure what makes you trouble about the customizing the context menu. You can use all thise stings in order to customize your context menu in the dock manager.
    ContextMenuFloating=&Floating
    ContextMenuAutoHide=&Auto Hide
    ContextMenuHide=&Hide
    ContextMenuDockable=Doc&kable
    I will recommend you to set this when the application loads, to be sure that the changes are done when you start using your dock manager.
    I hope this is solving your issue.
    Sincerely,
    Dimi
    Developer Support Engineer
    Infragistics, Inc.
