1110
UltraTextEditor unable to set border or background if hottracked with AppStylist
I have styled my application with the AppStylist and used the tab "Hottracked" of the UltraTextEditor so the border is changed when the users mouses-over the textbox. This works great but in code I want to be able to change the border color when the user types in a wrong value I want to make the border red.
It seems that these two will not work together because I cannot change the border color if hottracking is enabled.
Is there any way to do this or may temporary disable the hottracking in code? (I can't seem to find the property)
Erik
  • 469350
    Suggested Answer
    Hi Erik,
    I can't see any reason why the HotTracking would affect the border color when the control is not HotTracked. Unless maybe the HotTracking appearance is always applied when the control has focus. If that's the case, why not change both the bother color on the HotTrackAppearance and the regular appearance?
