Hi
I wish to export an UltraChart to a PDF as explained in the following document...
http://help.infragistics.com/Help/NetAdvantage/WinForms/2009.1/CLR2.0/html/Chart_Export_to_PDF.html
...however my Infragistics.Documents namespace does not exists. Under the Infragistics namespace I only have the following 5 items:
Excel, Shared, UltraChart, UltraGauge, Win
Do you know how I can get the Documents namespace items to display in the Intelesence.
Many thanks,
Dave
Yes worked perfectly, should have really been able to figure that one out for myself.
Many thanks
You have to add a reference to Infragistics.Documents assembly. For example, if you're using version 9.2, you will need to add a reference to Infragistics2.Documents.v9.2. You should be able to find this assembly in your Infragistics installation directory or in the global assembly cache
