315
Line chart is not displaying lines properly.
When i tried pass data to line chart, it doesno't draw line properly. It is displaying streight lines from left to right. See attached image file.
private void LoadChartData()
SqlConnection con = new SqlConnection("Initial Catalog=Northwind;User=sa;Password=******;Server=PCxxxx");SqlCommand command = new SqlCommand("Select Count(*) as Total, ShipCountry from Orders group by ShipCountry");
con.Open();
command.Connection = con;
DataSet ds = new DataSet("Orders");SqlDataAdapter adapter = new SqlDataAdapter(command);
adapter.Fill(ds);
ultraChart1.DataSource = ds;
ultraChart1.DataBind();
 Infra Line Chart Problem
  • 26458
    There was no image attached, but I think the problem is that your line chart displays a line for each row in your data set (which is its default behavior). Try setting ultraChart1.Data.SwapRowsAndColumns = true.
