Is it possible to embed a button in a TabControl header?
Justin
I'm looking to add a menu to the Tab Headers. Specifically I've been tasked to do this.
I can use the UltraDropDownButton to open the menu but have not been able to find a way to add the button to the Tab Header. Is this supported?
Thanks for the ideas Mike. I ended up just placing a button in the wanted place at load time and had it hover over the tab control header area. I'm handling placement in resize events.
Are you just looking for a close button? Because this is available by setting the UltraTabControl.CloseButtonLocation to Tab. If you want some other button, you can probably just reuse the close button. You can change the button image by setting the CloseButtonAppearance.Image property. And then you can handle the UltraTabControl.TabClosing event. Set Cancel to True on the event args so the tab doesn't actually close and then perform your button click logic. However, with this solution, you lose the ability for the user to close the tabs.
