465
Read Excel file and populate a DataReader/DataTable
Hi all,
is there a way - using an openFileDialog - to pass the stream of an Excel file to a DataReader that then I'm using with this code:
using
(SqlBulkCopy bulkCopy = new SqlBulkCopy(sqlConnectionString))
bulkCopy.DestinationTableName =
"ExcelData";
bulkCopy.WriteToServer(myDataReader);
Thanks in advance.
Luigi
  • 469350
    Suggested Answer
    Hi Luigi,
    I'm not sure I understand your question or what it has to do with the UltraWinEditors controls.
    If you are using the Infragistics Excel assembly, then you can load an Excel file into a Workbook object. But there's no way to translate that directly into anything the DataReader would be able to understand.
