1500
Set a cell's display value without taking the focus
In our application there is the linking functionality that is very similar to Excel's. A cell may reference other cells (=A1 + B3) as well as other entities of the application, like nodes in the tree (=nodeA). We have the fx bar that is actually the same as Excel's.
The use case under discussion is this: when a user is entering a formula for a cell in the fx bar (again, like in Excel), the formula should be mirrored in the grid's cell as the user types it. Our grid (that is based on Infragistics grid) has the SetActiveCellText method that should do the trick. The implementation of the method is as follows (a little simplified for brevity):
public void SetActiveCellText(string text)
    ultraGrid.PerformAction(UltraGridAction.EnterEditMode);
    ultraGrid.ActiveCell.SelStart = 0;
    ultraGrid.ActiveCell.SelLength = text.Length;
    ultraGrid.ActiveCell.SelText = text;
That works fine except the grid takes the focus during entering edit mode tha actually sounds quite locally.
That was the context for the problem and the question I have is: Is there a way to set grid's active cell selected text without the grid taking focus?
Vitaly
