530
Intermittent unhandled exception when setting focus to checkbox formatted cell
I receive an unhandled exception when setting focus to a checkbox formatted cell. How do I recode this so I don't receive an error? This error occurs randomly.
Here's my code:
grdBOL.Rows(0).Cells!Process.Activate()
grdBOL.Rows(0).Cells!Process.Selected = True
If grdBOL.Rows(0).Cells!Process.CanEnterEditMode Then grdBOL.PerformAction(UltraGridAction.EnterEditMode, False, False)
************** Exception Text **************
System.InvalidOperationException: Can't access SelectionStart unless the Editor is in edit mode.
   at Infragistics.Win.EmbeddableEditorBase.get_SelectionStart()
   at Infragistics.Win.EmbeddableTextBox.PositionControl(Rectangle bounds)
   at Infragistics.Win.EditorWithText.DisplayTextBox()
   at Infragistics.Win.EditorWithCombo.DisplayTextBox()
   at Infragistics.Win.EditorWithText.OnBeforeEnterEditMode(Boolean& cancel)
   at Infragistics.Win.EmbeddableEditorBase.EnterEditMode(EmbeddableUIElementBase embeddableElement)
   at Infragistics.Win.UltraWinGrid.UltraCombo.OnEnter(EventArgs e)
   at System.Windows.Forms.Control.NotifyEnter()
   at System.Windows.Forms.ContainerControl.UpdateFocusedControl()
   at System.Windows.Forms.ContainerControl.AssignActiveControlInternal(Control value)
   at System.Windows.Forms.ContainerControl.ActivateControlInternal(Control control, Boolean originator)
   at System.Windows.Forms.ContainerControl.ActivateControlInternal(Control control)
   at System.Windows.Forms.Control.WmSetFocus(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
  • 469350
    Suggested Answer
    Are you sure you are setting focus to the correct cell? The call stack here shows an error when entering edit mode on an UltraCombo, not a CheckBox. I can't tell if it's a standalone UltraCombo control on the form or a Combo embedded inside a grid cell, but I don't see anything here that indicates the involvement of a CheckBox in any way.
    This would make a lot of sense if grdBOL was actually an UltraCombo instead of an UltraWinGrid. Maybe you are just looking at the wrong control?
