Folks,
I have a ultrawingrid 8.2 with couple of columns having a dropdown to allow users to select a value from it. The dropdown (ultradropdown) is bound to the grid cell by setting the valuelist property for the column in the grid. The columns are mandatory and if user does't enter a value, i have to highlight the cell in red color (some color).
I tried to set the cells.appearance.backcolor = color.red, but it doesn't take effect. Is it because of the valuelist bound to the cell. Is there any other way to show some colors in the dropdown bound cells?
You hit the nail on its head ! I have to give it to you.
I was overriding the active row appearance in initialize layout. I removed it and reset the active row and active cell apperances. It worked like a charm. Thanks a ton.
Okay, I ran your sample and I see the problem.
It doesn't seem to have anything to do with the ValueList, though. Removing the ValueList from the column makes no difference.
It seems like the issue here is that you have an ActiveRowAppearance applied to the grid and this is overriding the appearance on the individual cell in the row. So you need to take off your ActiveRowAppearance on band 0 that your code is applying.
Also, the grid has a default ActiveRowAppearance applied, so you have to get rid of that, too.
FAQ:How do I turn off the ActiveRowAppearance so that the active row in the grid does not appear selected.
I'm attaching a sample project with the same grid settings that i had i my project. Run the .exe and click submit button.
No, that should not make any difference.
I just tested this out and it's working just fine for me. There must be some other factor at work here that we are missing.
Can you duplicate this in a small sample project?
Valid point Mike. I don't use any appstylist or any appearance to the dropdown, but i'm not able to set back color to the cells. I'm setting the column style of the grid to dropdownlist. Is that a reason ?
