1401
Getting the minimum value in UltraWinGrid
I have a column which can have null values. Now to get the minimum value in the column the infragistics API to get these is always returning as 0. I reckon it is assuming the null values as being zero. Is there a way to override the null values and fetch the minimum value from the list.
  • 469350
    Suggested Answer
    what method are you referring to? I assume you are using a Summary. Are you using the built-in Minimum summary type? Or are you using a formula?
    Whichever one you are using, you might want to try the other one and see if it behaves differently. I suspect you are probably using the Minimum SummaryType, but that if you use a formula, it will work the way you want.
    If you use a formula, remember to add an UltraCalcManager component to the form, if you don't already have one.
    If none of that works, then the other option is to write your own ICustomSummaryCalculator.
