Hi all,
As shown in the image below (attached), there are glitches at the end of stack chart. The corresponding data does not have these values. It should be smooth at the end.
Please help us to resolve this issue.
Thanks and regards
Kumar Nagaraju
the next service release is planned for January. to be notified when it becomes available, please enter a support incident at http://infragistics.com/gethelp and give them the bug number.
Thanks for the update David. Can you please let me know when will the next service release be available. And also how will I get communicated about such a release.
Thank you for reporting this problem. I entered it into our bug tracking system (# 25747) and fixed it. It should be resolved in an upcoming service release.
Feel free to inquire about the status of this issue at any time by posting back here or contacting Infragistics Developer Support at http://infragistics.com/gethelp
Hi David,
Thanks for your reply.
In order to reproduce this problem, please use chart type as StackSplineAreaChart
instead StackAreaChart in above code.
Thanks and Regards,
i was not able to reproduce this problem using this code on a new form:
private void Form1_Load(object sender, EventArgs e) { UltraChart ultraChart1 = new UltraChart(); ultraChart1.Dock = DockStyle.Fill; this.Controls.Add(ultraChart1); ultraChart1.ChartType = ChartType.StackAreaChart; DataTable table = new DataTable(); table.Columns.Add("one", typeof(double)); table.Columns.Add("two", typeof(double)); for (int r = 0; r < 100; r++) { table.Rows.Add(new object[] { r, r }); } ultraChart1.Data.DataSource = table; ultraChart1.Data.SwapRowsAndColumns = true; ultraChart1.Data.DataBind(); }
can you advise me on how to reproduce the problem you described?
