I'm using the Card View of an UltraGrid, which displays a vertical scrollbar if the contents of a single card don't fit vertically in the container, as described under "CardView Scrolling" in:
http://help.infragistics.com/Help/NetAdvantage/WinForms/2009.1/CLR2.0/HTML/WinGrid_Whats_New_2005_1.html
My question is, when the user scrolls this view, how can I get the vertical scroll position - i.e. what event should I subscribe to, and what property should I check?
I don't think the cardview scrollbar is exposed and I can find no event that fires when this scrolbar is scrolled.
You should Submit a feature request to Infragistics
