Hi all,I've not found a way to set bold every column caption in my UltraGrid.What's the exactly way to do so?
Thanks in advance.
Luigi
Perfect, it works fine.
Thank you very much Mike.
private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e) { e.Layout.Override.HeaderAppearance.FontData.Bold = DefaultableBoolean.True; }
