Hi
I would like to track the edit mode in an UltraCombo, i.e. I'm looking for functionality similar to the IsInEditMode flag and the Before/AfterEnterEditMode & Before/AfterExitEditMode events on the TextEditorControlBase.
Is there a way to do this?
thanks & kind regards,olivier
Hi Olivier,
I'm not sure if this is a bug. It seems like an oversight, but it's possible that these events were left out intentionally because of some technical limitation. Like I said, the UltraCombo was originally not designed as an editor, it was updated later. So maybe there is some stumbling block there that makes it difficult to properly raise the EditMode events.
Feel free to report it to Infragistics Developer Support as a bug, if you like, and it will get looked at. :)
Hi Mike
thanks for the hint. I took a look at the UltraCombo code and managed to do it using the Enter/Leave events.
Should I post an Issue?
olivier
I'm not sure why the control doesn't expose these properties and events. Probably just an oversight, since the UltraCombo was originally not an embeddable editor.
You could use the Enter and Leave events, and the ContainsFocus method for essentially the same things, though.
