355
Reset the AddRowTemplate after cancel update
I'm using a grid with AllowAddNew set to  AllowAddNew.FixedAddRowOnTop and in BeforeRowUpdate I make some validation to decide if changes will be updated in the data source or not. When validation failed I set e.Cancel to true to cancel update, this work fine but the row (that is the add row template) become a non add row template that means  that IsAddRow property return false, even after pressing ESC the row still non add row template and this is a problem for me because I'm setting some row properties based on this propertie.
How can I reset the add row template?
Best regards.
